Lenco turntable project - 29/06/16 more progress
Post by sph on Mon Apr 27, 2015 10:15 pm
hi Lenco enthusiasts,
I am sure many of you have heard of the PTP which is used to bring the Lenco turntable to another level of performance.
The original PTP is way off my budget. But the PTP concept did interest me and I decided to make my own version of the PTP for less money.
So the last few weeks I have been having a closer look at my Lenco to see how I can come up with a decent design for the top plate.
I have finally made a prototype from mild steel and the testing was done over last 2 days. The result was highly satisfactory. What needs to be done now is to have the top plate done in 4mm stainless steel plate.
A few friends from this forum have already expressed their interest in the top plate and are eagerly waiting for the finished product. I am thinking of making a batch of 10 plates to be able to negotiate a good price for CNCing the top plate. 6 units have been booked, leaving 4 available.
I am offering the remaining 4 to forum members. Each plate will cost MYR----ringgit. The final figure has yet to be negotiated. Price now is MYR450. If interested, PM or WhatsApp me (012-218 8600, no calls pease) as soon as possible for more details and photos of the project.
Cheers.
sph
sph
Number of posts : 326
Registration date : 2009-03-04
Re: Lenco turntable project - 29/06/16 more progress
Post by sph on Mon May 11, 2015 11:27 pm
The first finished sample (made from 4mm stainless steel) of the top plate was delivered to me today.
The top-plate was mounted on a mock plinth for a trial run. Very happy with the results.
sph
Post by Tonedeaf on Tue May 12, 2015 7:14 am
Nice!
PM sent.
Tonedeaf
Number of posts : 1
Registration date : 2015-04-29
Post by sph on Mon Jun 08, 2015 9:03 pm
The top plates have been cut and collected.
The top plates are now slightly slimmer.
I have also made two stainless steel mat for testing.
The finished top plates .......
sph
Post by sph on Thu Sep 17, 2015 9:51 am
The top plates are being implemented in my current Lenco project.
The plinth awaits gluing the layers of plywood and finishing while the tonearm a head-shell (diy too).
The tonearm is a diy Well Tempered Arm.
sph
Post by sph on Sat Oct 31, 2015 11:45 pm
Finally completed the project with the DIY Well Tempered tonearm.
Cartridge is a aluminum bodied AT95e (modified).
[url=]
sph
Post by sph on Thu Jan 28, 2016 7:40 pm
Photos of recently completed turntables.
With Shroeder tonearm:
sph
More progress
Post by sph on Wed Jun 29, 2016 9:55 am
My "Project Lenco" has now advanced into new territory.
I have made accessories to bring the Lenco to another level, the most significant of which is the stainless steel mat, the SSSmat (MYR380).
The mat is made from the same 4mm stainless steel as the top plates and weighs 2kg. The 2kg weight gives the platter system added inertia which results in greater rotational stability of the platter.
Another accessory is the bearing clamping collar (MYR90). This again is made from 4mm stainless steel. The purpose is to stiffen the area surrounding the bearing to reduce the flexing of the thin 2mm steel top plate. Sold many in Lencoheaven and eBay already.
Another accessory (more like a replacement part or tweak) is the 2 tungsten carbide bearing balls and POM thrust pad (MYR30 3-items combo)
First is the 2.5mm ball which replaces the thrust pad in the motor nose screw. See the link in Lencoheaven http://www.lencoheaven.net/forum/index.php?topic=6100.0
This tweak makes the motor more silent.
Next tweak is the 5mm tungsten ball with the 1mm thick POM pad. POM is short for polyoxymethylene, which is hard but smooth kind of plastic. In most Lencos the 0.5mm Nylatron thrust pad is often badly dimpled by the steel ball from the pressure exerted by the weight of the platter. The result from this tweak is a smoother rotation from the bearing.
PM or WhatsApp me 012-2188600 (no calls please) for inquiries.
sph
Post by vt4c on Wed Jun 29, 2016 9:16 pm
Great collection of TT...the Garrard 301, Thorens TD124 and the now Lenco.
vt4c
Number of posts : 133
Registration date : 2009-05-09
Post by sph on Thu Jun 30, 2016 9:55 am
The Thoren and Garrard are not mine .... belong to customer.
sph
Post by vt4c on Fri Jul 01, 2016 10:25 pm
Is that a Schroeder arm in one of the picture? Great set-up
vt4c
Post by sph on Sat Jul 02, 2016 7:14 am
Yes, it is a Schroeder arm - a customer's. Installed onto the SLAT-ed Lenco.
sph
Post by sph on Mon Jul 18, 2016 4:40 pm
Recent custom built SLAT-ed LENCO turntables....
sph
Post by sph on Mon Sep 26, 2016 3:02 pm
A recent build...
sph
Post by DedeBarre on Thu Oct 06, 2016 1:35 am
Hi..i am a new user here. Thanks for sharing your project here. I am also looking to build the same. Can you please share the all accessories you used to built this with their specifications? Mainly i want to know about the hardware components you used here.
DedeBarre
Number of posts : 1
Registration date : 2016-10-05
Post by sph on Thu Oct 06, 2016 12:59 pm
The main parts are all from the Lenco 70, 75 or 78 turntable. These are the motor, bearing and idler wheel assembly.
The other hardware are available from me. These parts are the SLAT (top plates) and its accessories ( manual speed lever, on-off/park lever, string kit) and the stainless steel armboard.
sph
