Yamaha's Flagship Aventage CX-A5100 AV Pre amp, 11-Channel MX-A5000 Power Amplifier
Post by actsessory on Sun Apr 10, 2016 10:40 pm
If you’re in market for a high end, no compromise preamp-processor, Yamaha’s new flagship AV pre-amp processor, the Aventage CX-A5100 may very well in your short list.
CX-A5100 meets all of today’s HD audio and video formats now and the foreseeable future.
11.2 channel pre-pro that has been designed to mate with Yamaha 11-channel MX-A5000 power amplifier.
The CX/MX duo “reference status”
Yamaha’s flagship two-piece is frankly powerful enough to bring a small hall to the brink of sonic meltdown.
This long-awaited flagship will fast-track you to the best AV thrill ride in town.
In terms of sheer might and depth, no other home theatre product I’ve used has come close..
In tandem they are exhilarating and able to enliven even the dullest-sounding speakers.
State-of-the-art connectivity and all the features the serious home theatre fan could want.
Superseding its predecessor (the CX-A5000), CX-A5100 adds a number of important feature for high-end home theater installation:
– Dolby Atmos & DTS:X immersive surround sound
– Dual XLR subwoofer outputs for support up to 7.1.4 channel speaker configuration
– HDMI 2.0a, HDCP 2.2 and 4K/UHD (up to 60p, 4:4:4), UHD upscaling, support HDR (High Dynamic Range) via firmware upgrade.
..plus all standard that is making this a future-proof model.
Four zones (2 HDMI outputs with independent, matrix switching; Zone 3&4 being audio only)
World-class ESS Sabre Ultra DAC ES9016S for ALL CHANNELS, with independant Yamaha clock circuit (Ultra Low Jitter PLL) to eliminate jitter.
Decode all major high-res formats including DSD (2.8MHz and 5.6MHz), Flac, Wav, Aiff at 192kHz / 24-bit. ALAC (Apple Lossless, limited to 96 kHz / 24-bit)
Played from networked PC, NAS, USB, AirPlay, Bluetooth, Spotify, Pandora….via ethernet / WiFi
Support Yamaha’s new MusicCast wireless music streaming platform.
CX-A5100’s new 64-bit architecture takes on-board power to a new level! It applies Yamaha’s YPAO room correction on lossless files at full 192kHz/24-bit without down-sampling.
(Many well-known system down-sample all hi-res files to 48kHz. Some real expensive, higher end system like Anthem’s ARC is still be limited to 96kHz…)
Comes with a 3D, multi-point, and angle measurement microphone for room correction and all necessary adjustments automatically.
This 64-bit YPAO 3D system in A5100 represents the most advanced evolution of YPAO up to today, it’s designed to reduce noise when measuring frequencies – the benefits are audible in the lower frequencies, meaning a tighter, flatter response which translates into a more open sound.
The 3D measurements precisely locates the presence speakers and is said to do so within 1 inch of actual measured distance.
Contrary to most competitor Room EQ systems, YPAO works up to 192 kHz
The CX-A5100’s parametric equaliser produces superb room correction, including extensive bass management.
H-frame to strengthen the chassis with a fifth foot to keep everything stable.
The enclosure features a sturdy frame with an H-shaped crossmember for rigidity.
Yamaha’s Signature proprietary ART (Anti-Resonance Technology) Wedge at center of the underside of the chassis, is claimed to provide vibration control for the internal circuits.
– Aluminum front panel, H-shape cross member frame and rigid bottom frame
– AV Controller App
– YPAO™ – R.S.C. with 3D, multipoint and angle measurement
– CINEMA DSP HD3 expands the sound field vertically for more thrilling and realistic surround sound
– Professional DAC (digital-to-analog conversion) ESS SABRE™ Ultra DAC ES9016S for all channels, 192 kHz / 32-bit processing with a superior SN ratio and high dynamic range
– 4K Ultra HD Full Support with 4K60p, HDCP2.2, HDR* Video and BT.2020 pass-through
– Advanced HDMI® zone switching allows unprecedented AV switching to multiple zones
– Vibration damping with unique foot, ART (Anti-Resonance Technology) Wedge in the center of the bottom cover acts as an additional vibration countermeasure for the internal circuits and delicate parts.
– Noise Resistant, Highly Reliable Balanced Connections and High Quality XLR Terminals for Long Subwoofer Cables
– Sound Tuning Achieved with High Quality Parts for Optimum Performance
[You must be registered and logged in to see this link.]
*Built like a tank
*The two-channel performance sounds fantastic, and for movies, which are my passion, this beast kicks some serious tail.
**Highly recommended.
Top Picks:
Plus
Audiophile sound quality
Best-in-class control for iOS and Android
Dolby Atmos and DTS:X support
Built-in MusicCast multiroom audio
To me there are two main features you want in a processor today: you need high-end DACs to get the best audio quality from digital sources, and you want to pair that with room correction that works well.
It is as ready for the future as anything can be today..
* Retails RM12500
*  1 Year + 6 Months Warranty by Yamaha Malaysia
* Credit Card is accepted
Yamaha Aventage MX-A5000 11-Channel Power Amplifier
“A genuine bargain for such great sound + 11-channels”
Absolute Quality. Massive Power.
Reference standard build quality. Top-Grade AVENTAGE Series performance.
A no-compromise design policy for this amplifier
The muscular, matching MX-A5000 amplifier is a discrete structured 11 channel power amplifier perfectly matched to the CX-A5100 AV processor.
It utilises its discrete amps to deliver astonishing levels of power.
It boasts 150W (at 8ohm, full range, 2-ch driven) power output for all 11 channels with a phenomenally low THD of just 0.06%.
Yamaha’s CX-A5100/MX-A5000 pairing makes a superb choice for a high-end home theatre.
Overwhelming Power and High Density Presence Achieved by 11.2 Channel Separate AV Amps
The key to MX-A5000 sonic signature is its current feedback, which reacts in real-time, allocates additional power resources from channels and not using their full allocation of power.
It intelligently allocates this unused power to channels demanding more especially in ‘power-hungry’ scenes and sound tracks.
The current feedback uses three stage Darlington circuit that has superior phase properties and is resistant to speaker impedance fluctuation.
Very useful when you have lower-sensitivity speakers or when you’re watching movies with a high dynamic range soundtrack.
The amplifier seemingly cruises through these passages without fuss.
The 11 channel power amp is configurable to use as 11 full range channels, or 5 bi-amped channels, or a bi-amped 2nd zone and another pair of speakers in a 3rd zone.
Benefits from the AVENTAGE ethos by using only the best components, highest quality parts, like a high-output toroidal power transformer and two 27,000μF block capacitors to ensure abundant power delivery and optimum performance.
All parts are strictly selected based on listening tests.
Greater Sound Purity with Specially Designed High Rigidity Advanced Chassis that eliminates vibrations.
H-frame to strengthen the chassis, bootsting mechanical strength, with a fifth foot to keep everything stable.
Yamaha’s signature A.R.T. (Anti-Resonance Technology) Wedge in the center of the bottom cover acts as an additional vibration countermeasure and firmly supports the internal circuits.
The large toroidal transformer and the high capacity (27000uf) block capacitors are positioned close to the centre.
The fifth foot, clearly visible below, helps to stabilise the huge transformer which is positioned right above it.
Independent top cover and side panels
The brushed aluminium side panels look absolutely gorgeous.
Plus a double bottom, of vibration control plates made of 1/8 inch (1.6 mm) black steel, the same type of construction used on the previous flagship model Z11.
Symmetrical Power Amplifier Layout – precisely planned, left and right channels are physically and electrically isolated.
This naturally maximizes channel separation, also greatly improves signal to noise ratio to achieve a wide, open sound stage.
  • 150 W per channel (8 ohms, 20 Hz-20 kHz, 0.06% THD, 2 ch driven)
  • 170 W per channel (8 ohms, 1 kHz, 0.9% THD, 2 ch driven)
  • Custom made, large-size toroidal transformer
  • Current feedback power amp with three stage Darlington circuit
  • 27,000μF custom block capacitors
  • Specially designed high rigidity chassis and highest quality parts
  • Noise resistant XLR balanced connections
  • Bi-amping capability with channel selector
  • High quality gold-plated speaker terminals
  • Auto Power Standby
  • Handy trigger control (trigger in / out and through out )
  • Detachable high quality thick AC power cord
  • Power Consumption 650W
  • Weights at 25.4 kg
  • Dimension: 17-1/8″W x 8-1/4″H x 19-3/16″D
High output, high efficiency, large size toroidal transformer, two specially developed high capacity (27,000μF) block capacitors, ensures sound capable of superior musical expression.
“One brute of a power supply; check out those caps”
Speaker output terminals are high quality gold-plated types
In Addition to 11.2 Channel Output, 5 Channel Bi-amping and Other Configurations Are Possible
Extra amps can be used to power multiple zones in addition to the main room, letting you configure your system for music play in a bedroom or kitchen.
“The MX-A5000 has generous connection space”
Speaker Impedance Selection
The impedance selector on the rear panel of the MX-A5000 matches amplifier output current to various speaker impedances.
EISA AWARD 2014-2015
Great product!!!!
 Distributes the sound evenly and marvelously. I’ve never enjoyed movies like that before.
 I have been used Yamaha back in 1988,CX-1000 & MX-1000 for all those years and its still kicking they put out excellent power, clean & purest sound, So I just bought a new Yamaha CX-A5000 & MX-A5000 these systems are awsome the sound is just blow my mind versus my old system they both excellent,but the new one is punchier
This is probably the last amp I ever own
“This amp can deliver and hold current for deep bass and intense dynamic bursts of main channel audio and surround effects, as well as high-res multichannel music playback from Blu-rays or music-download sources, such as 2L.”
“The Yamaha kicks butt with the Bruce Willis Live Free and Die Hard soundtrack.
Clean, dynamic and open! That is what you want from AV amplification.”
“Strain is not a word you can associate with the Yamaha. The BD soundtrack’s sonic signature, like the AudioControl receiver’s, was big and imposing with a great width and space spread among the tracks’ varying elements. Right off the bat, I could tell that the MX-A5000 has the capability to relay the massive dynamics of the linear PCM soundtrack.”
"All in all, the Yamaha MX-A5000 excels not only at playing your movie soundtracks, but also is a pretty darn good music amp
If you want it all in one amp, this is one to consider.
I did not have any complaints with the Yamaha MX-A5000.
Easy to setup, plenty of space for the speaker cables to co-exist with the input cables, and it has a 12V trigger for remote turn on.
In the context of high-end multichannel amps, I rank the Yamaha up near the top — especially with its price tag at under $3,000"
by John Gatski - Reviewer for • Audiophile • Home Theater • Personal Audio • Home Recording
* Retails RM10900
Contact 012 6116917
Subang Jaya SS 14
actsessory
Number of posts : 929
Registration date : 2013-10-25
http://www.actsessory.com
Re: Yamaha's Flagship Aventage CX-A5100 AV Pre amp, 11-Channel MX-A5000 Power Amplifier
Post by actsessory on Sat Apr 30, 2016 11:17 pm
Ready stock, ready deal.
actsessory
Post by actsessory on Tue May 31, 2016 11:49 pm
Welcome for inquiries.
actsessory
Post by actsessory on Mon Aug 29, 2016 6:42 pm
actsessory
Post by actsessory on Wed Sep 21, 2016 10:47 am
actsessory
Post by actsessory on Sat Feb 25, 2017 12:40 pm
Demo available soon...
actsessory
Post by hwteh on Sat Mar 18, 2017 5:43 pm
actsessory wrote:Ready stock, ready deal.
Chong, how much for both cx and mx?
hwteh
Number of posts : 3
Registration date : 2016-02-18
Post by actsessory on Wed Jun 28, 2017 3:19 pm
Ready stock.
actsessory
Post by actsessory on Sat Jul 22, 2017 5:27 pm
Pre and post system bump
actsessory
Post by actsessory on Tue Aug 15, 2017 9:46 pm
Stock in hand.
actsessory
Post by actsessory on Sun Oct 22, 2017 8:16 pm
actsessory
Post by actsessory on Tue Nov 14, 2017 7:12 pm
ready stock
actsessory
Post by actsessory on Thu Dec 07, 2017 7:57 pm
actsessory
