Mirage MM-6 Ultra-compact Powered Subwoofer
Post by raymond88 on Thu Jun 09, 2016 1:12 pm
Item: Mirage MM-6 Ultra-compact Powered Subwoofer
Condition: 8.5/10. Item in excellent condition. No scratches or dents.
Price: sold
Contact: 012-3816611
Actual pic of item in use:
Our smallest powered subwoofer to date, the MM-6 packs intense, full-bodied bass into a miniature 8-inch cube that fills your room with magnificent sound.
  • Sleek little cube blends perfectly with any décor
  • High-gloss black finish hand-sanded to perfection
  • Neatly tucks away under a table or in a corner
  • 6.5-inch woofer and dual passive radiators deliver powerful deep bass
  • Ribbed Elliptical Surround technology provides true depth without
Marvelously Miniature
In order to achieve dynamic home theater and music listening experiences, there's no question: you need a subwoofer. And, while you'll feel its thunderous bass, the MM-6 won't steal it away from your decor; as it neatly tucks away under a table or in a
corner.
The MM-6's exceptional looking cabinet is constructed of rigid medium density fiberboard and finished in a furniture-grade high-gloss black, achieved via seven layers of hand-sanded polyurethane. Inside, the MM-6 packs premium materials and advanced technologies that let you experience the full impact of your music and movies.
Pair the MM-6 with the immersive sound of any of our other speakers and experience home audio entertainment like never before.
[b][b][b][b]System Type[/b][/b][/b][/b]  Single active, dual passive
[b][b][b][b]Variable Low Pass Filter[/b][/b][/b][/b]  50Hz-200Hz, Bypass
[b][b][b][b]Variable Phase Control[/b][/b][/b][/b]  0 degrees - 360 degrees
[b][b][b][b]Weight (Kg/lb)[/b][/b][/b][/b]  10.1 lbs (4.6 kg)
[b][b][b][b]Power Mode Switch[/b][/b][/b][/b]  Off/auto/on
[b][b][b][b]Inputs[/b][/b][/b][/b]  L + R Line in/Sub in
[b][b][b][b]Product Finish[/b][/b][/b][/b]  High gloss black
[b][b][b][b]Frequency Response (Hz, +/-3dB)[/b][/b][/b][/b]  42Hz-200Hz
[b][b][b][b]Part Number[/b][/b][/b][/b]  1009510
[b][b][b][b]Overall Dimensions (mm/in, HxWxD)[/b][/b][/b][/b]  HxWxD, 8 x 8 x 8 inches , 20 x 20 x 20 cm
[b][b][b][b]Woofer[/b][/b][/b][/b]  Active: 6.5-inch (16.5 cm) Black anodized aluminum cone with inverted Ribbed Elliptical Surround, Passive: 2 x 6.5-inch (16.5 cm) Black anodized aluminum cones with inverted Ribbed Elliptical Surround
[b][b][b][b]Amplifier Power Output[/b][/b][/b][/b]  800 Watts
[b][b][b][b]Max SPL[/b][/b][/b][/b]  97dB @ 30Hz, ground plane, 1m
[b][b][b][b]UPC[/b][/b][/b][/b]  629303-40025-8
Website:
http://www.miragespeakers.com/subwoofers/?sku=MM-6
http://www.crutchfield.com/S-NJZiEHm13qb/p_653MM6/Mirage-MM-6.html
See my other stuffs here:
https://carousell.com/raymondhifi/
Thank you
raymond88
Number of posts : 3568
Registration date : 2009-05-04
http://www.mudah.my/hifi-junction
Re: Mirage MM-6 Ultra-compact Powered Subwoofer
Post by raymond88 on Thu Jun 23, 2016 4:50 am
raymond88
Post by raymond88 on Thu Jun 30, 2016 8:37 pm
raymond88
Post by raymond88 on Sun Oct 30, 2016 11:30 am
raymond88
Post by raymond88 on Tue Nov 08, 2016 11:32 am
raymond88
Post by raymond88 on Sun Nov 27, 2016 11:06 pm
raymond88
Post by raymond88 on Wed Dec 14, 2016 7:04 pm
raymond88
Post by raymond88 on Sat Jan 07, 2017 1:03 pm
raymond88
Post by raymond88 on Tue Jan 31, 2017 11:35 pm
raymond88
Post by raymond88 on Mon Feb 20, 2017 7:33 pm
raymond88
Post by raymond88 on Tue Mar 21, 2017 11:58 pm
raymond88
Post by raymond88 on Thu Jun 01, 2017 12:11 am
raymond88
