Classic NAIM Audio System -Pre-Amp, Power Amplifier with SNAPS
Post by mav on Sun Nov 13, 2016 10:19 am
Naim’s “WORLD CLASS SOUND…”
Beautifully designed Classic Chrome Bumper Naim Audio power and pre-amplifier with Naim SNAPS.
Made in England
Naim NAC 42 Preamp with voltage supply cable and signal cable (RCA)
Tuner, Phono, Tape inputs but can be used with other sources, includes SNAIC cable to connect pre and power amp as well as mains lead.
One of the earlier preamp’s manufactured by Naim Audio, mid 80’s
*NA 328/2 boards installed.
For non-NAIM CD Player, 328 boards gives a more Naim-like sound.
Naim Audio NA 328/2 Variable Line Level boards to allow an extra line input and to attenuate high level source signal (CD/Tuner)
“NA 328 has variable sensitivity for high-level inputs, 25 mV – 375 mV, 47 kOhms impedance.
The preset on NA 328 should be adjusted using small insulated screwdriver, turn anti-clockwise for maximum gain, clockwise for
minimum gain.
Turn fully clockwise for use with CD players.”
Designed to be used with Naim SNAPS power supply (which had a single 24 volt rail)
Outboard power supplies were offered by NAIM Audio to improve performance of both the preamp and amps, a quieter source which enables the preamp/amp to operate solely as individual.
Naim NAP 110 Stereo Power Amplifier
45 watt per channel into 8 ohms of Naim amplification (high gain, high current) to drive low efficiency speakers
Original Naim 4-pin signal cable included.
The power inlet was a round 3 pin one circa 1980’s which Naim used up to the introduction of the more modern “kettle” type IEC  socket.
It accepts RCA line level signal as well.
Fantastic legendary Pre and Power amps which punches well above its weight for “clarity”, “power“ and “timing”.
Great cosmetic condition, electronically perfect!
RM3380
Welcome for audition @ Subang Jaya ss14
*Credit cards accepted.
Contact O16 440714O
https://actsessory.com/pre-owned-used/
mav
Number of posts : 280
Registration date : 2010-09-21
Re: Classic NAIM Audio System -Pre-Amp, Power Amplifier with SNAPS
Post by mav on Mon Nov 21, 2016 7:41 pm
Welcome
mav
Post by mav on Tue Dec 13, 2016 10:33 pm
Cash / Card accepted
mav
Post by mav on Thu Dec 29, 2016 12:25 pm
mav
Post by mav on Thu Feb 23, 2017 12:59 pm
Cash/card accepted.
mav
Post by mav on Fri Mar 03, 2017 3:29 pm
mav
Post by mav on Mon Mar 13, 2017 5:21 pm
Bump...!
mav
Post by mav on Wed Mar 22, 2017 4:36 pm
item still available...
mav
Post by mav on Tue Apr 04, 2017 11:56 am
mav
Post by mav on Thu Apr 13, 2017 12:19 pm
mav
Post by mav on Wed Apr 26, 2017 6:03 pm
Contact O16 440 714O
mav
Post by mav on Mon Oct 23, 2017 9:51 am
available
mav
Post by mav on Wed Dec 13, 2017 11:12 pm
mav
