SVS SoundPath Subwoofer Isolation System
Post by actsessory on Wed Jan 11, 2017 2:12 pm
  • Screw-In Elastomer Isolation Feet
  • Fits Most Subwoofer Brands
  • Improve Subwoofer Performance, Eliminate Room Rattle
  • Tighter and cleaner sounding bass
SVS SoundPath Subwoofer Isolation Feet, fits most subwoofer brands
Screw-In Elastomer Isolation Feet, Fits Most Subwoofer Brands, Includes Popular Thread Sizes/Lengths.
Improve Subwoofer Performance, Eliminate Room Rattle & Be a Better Neighbor
The SVS SoundPath Subwoofer Isolation System works with nearly every subwoofer brand and model to improve bass performance while reducing floor and wall vibrations, noise artifacts and complaints from neighbors or roommates.
De-coupling a subwoofer from the floor results in inherently tighter and cleaner sounding bass.
It’s also the next best thing to sound-proofing and ideal for carpeted rooms, hardwood floors or any space where room rattles, buzzes or vibrations are present.
Decoupling is making the interaction between a subwoofer and floor so weak that virtually no energy is transferred between them.
The SVS SoundPath Subwoofer Isolation System features rigorously tested optimized durometer elastomer feet that significantly reduces the transmission of subwoofer energy through your floor and walls.
This allows low frequency effects to be transferred through the air where they can be felt, resulting in tighter and cleaner sounding bass, no more distracting buzz or rattle from the room, and better sonic clarity and dynamics.
Overall Height: 40 mm
Shell Diameter: 58 mm
Foot Diameter: 53 mm
“These are surprisingly effective and do exactly as advertised.
My subs are now slightly tighter sounding, but more importantly bass travel through the floor and walls (into my neighbors house) is significantly reduced.”
“They tightened up the bass. As I said, great isolation system.”
“Excellent cost effective upgrade for your subwoofer.
Highly recommended to anyone looking for a solution to rid their subwoofer/s of unwanted vibrations.”
“Amazing difference, highly recommended, well worth the price
The bass became less boomy, more defined. What was a great sounding system, became an incredible system.”
“The SVS SoundPath Subwoofer Isolation is Doing great job replacing the footers from manufacturer(JL Audio). Bass is improved and the there is much less shaking from the furniture.”
“Cleaner sounding bass with increased definition and more punch…a significant decrease in bass bleed to the rest of the house…these are an absolute no-brainer upgrade.”
“If you’ve spent your hard-earned cash on a subwoofer you want to listen to at its full potential, and if the buzz and rattles in the room are frustrating you, this definitely is an answer to your problem. A true bargain. Highly recommended.”
“It took up less space and looked notably cleaner…produced an immediate and noticeable improvement in sound quality.”
“Gone was the flabby bass, gone was the rattling / vibration caused by the interface of the subwoofer to the ground.”
“Now, I’m enjoying my sub’s full impact without dealing with the floor vibrations that I’d also get as a byproduct. Thumbs up to the SVS team for a great product.”
“…a high-tech hemorrhoid pillow to cushion the sub. This produces less rattle and cleaner, tighter bass and helped to attenuate a pesky window rattle I’ve been fighting for years.”
“The SVS subwoofer isolation system is one of the most cost-effective bass isolation systems I’ve heard…” http://audiophilereview.com/subwoofers/svs-soundpath-subwoofer-isolation-system
Price: 4 FOOT RM310; 6 FOOT RM390
[You must be registered and logged in to see this link.]
[You must be registered and logged in to see this link.] - Like us
01 6366 5888, 012- 611691 7 @ Subang Jaya ss14
actsessory
Number of posts : 980
Registration date : 2013-10-25
http://www.actsessory.com
Re: SVS SoundPath Subwoofer Isolation System
Post by actsessory on Fri Feb 03, 2017 10:52 am
ready stock
actsessory
Post by actsessory on Tue Feb 28, 2017 2:04 pm
actsessory
Post by actsessory on Fri May 05, 2017 3:59 pm
Limited stock left.. last 2 sets
actsessory
Post by actsessory on Sat Jul 22, 2017 5:28 pm
Stock back in supply....
actsessory
Post by valtai30 on Thu Aug 03, 2017 10:04 am
Hi, is it suitable for Klipsch R115sw? 4 or 6 foots recommended?
valtai30
Number of posts : 10
Registration date : 2010-01-09
Post by stepyew on Fri Aug 04, 2017 6:27 pm
Is it need to be screw on to the bottom  of the sub surface?
My sub does not have the OE feet .
So is it possible to just use a double sided tape to bond the svs feet to the bottom of the sub surface ?
Incase you need to know the brand and the model no of the sub:-
Brand : genesis
Model no is : 928 or G928
stepyew
Number of posts : 7
Registration date : 2014-08-24
Post by actsessory on Sun Aug 13, 2017 1:16 pm
valtai30 wrote:Hi, is it suitable for Klipsch R115sw? 4 or 6 foots recommended?
Just 4 will do, follows the existing ones of your subwoofer and replace them with the SVS.
6 foots are meant for long length woofers like SVS PB13U, PB16U...
actsessory
Post by actsessory on Sat Oct 21, 2017 10:31 am
Ready stock for both 4 and 6 footer
actsessory
Post by actsessory on Sat Dec 09, 2017 12:27 pm
Bump
actsessory
Post by actsessory on Sun Jan 07, 2018 10:17 pm
Stock available.
actsessory
Post by valtai30 on Wed Jan 10, 2018 3:34 pm
Hi, originally don't have any foot, just flat base. Anyway, i want a 4 foots set. How to order? PM me ya. Thanks.
valtai30
Post by actsessory on Wed Feb 21, 2018 3:14 pm
Ready stock
actsessory
Post by actsessory on Thu Apr 12, 2018 4:05 pm
Available
actsessory
Post by actsessory on Tue Apr 24, 2018 12:21 pm
actsessory
Post by actsessory on Fri May 11, 2018 1:38 pm
Limited stock..
actsessory
Post by actsessory on Wed Jun 06, 2018 1:33 pm
Bump
actsessory
