Audioquest Sub-3 Subwoofer RCA Interconnect - 3m
Post by raymond88 on Mon Feb 20, 2017 7:29 pm
Item: Audioquest Sub-3 Subwoofer RCA Interconnect - 3m with 72vDBS
Condition: 8.5/10. Item is in excellent condition.
Price: RM850 or swap/topup
Contact: 012-3816611
Some info:
Manufacturer's Description:
SUB-3 uses three solid 6.1% Silver conductors inside PE Air Tubes. Solid conductors eliminate strand-interaction distortion. PE Air Tubes minimize information smearing caused by any solid or foam insulation. The 36V electrostatic field on the PE tubes almost eliminates remaining insulation induced distortion. Three conductors insure optimum performance single-ended (RCA plugs) or balanced (XLR plugs). A 100% coverage shield insures noise-free performance. Silver-plated plugs are welded to Sub-3 using 8,000 amperes.
Silver-Plated Copper (PSC) always provides superior performance for video and digital audio. Unfortunately, when used for full range analog audio, the discontinuity of plating silver over copper causes high frequencies to sound edgy and harsh. However, when used only for subwoofer frequencies, SPC's "artificial edge" actually enhances the articulation and intelligibility of low frequency information. Do not use Sub-3 as a full range audio cable.
DIRECTIONS: If you hear noticeable hum in your system after connecting your subwoofer, please attach Sub-3's little extra tails. Some equipment has a ground (GND) connection on the back-panel, if not, attach the little spade lugs to any screw on the equipment chassis of both the source and the subwoofer. Standard 12V batteries in the DBS pack will last several years. A test button and LED allow for the occasional battery check.
Websites:
https://www.crutchfield.com/S-NLgxQCFM3T5/p_703SUB33M/AudioQuest-SUB-3-3-meter-9-8-feet.html
https://www.musicdirect.com/store/audioquest-sub-3-subwoofer-cable
Thank you
raymond88
Number of posts : 3687
Registration date : 2009-05-04
http://www.mudah.my/hifi-junction
Re: Audioquest Sub-3 Subwoofer RCA Interconnect - 3m
Post by raymond88 on Mon Feb 27, 2017 1:16 pm
raymond88
Post by raymond88 on Wed Mar 08, 2017 6:38 pm
raymond88
Post by raymond88 on Mon Mar 27, 2017 11:06 pm
raymond88
Post by raymond88 on Sun Apr 23, 2017 12:13 am
raymond88
Post by raymond88 on Thu Jun 01, 2017 12:10 am
raymond88
Post by raymond88 on Mon Jun 26, 2017 2:40 pm
raymond88
