Rel Storm5 200-Watt MOSFET Subwoofer System, England
Post by mav on Thu Feb 23, 2017 3:01 pm
True 200W (continuous) discrete, direct-coupled MOSFET amplifier
Downward-firing long throw 250mm (10″) cast chassis driver
Closed (sealed) box “Zero-Q” loading system design
Set-Safe audibly transparent driver protection
Full action remote microprocessor control of all set-up parameters, make adjustments to the device from a seated position.
4 memories to store all functions
Improved ABC (Active Bass Control) filtering circuit calibrted in single Hz steps from 16 – 99 Hz
Double-sided glass-fibre boards with plated-through holes
Finished in 30mm MDF in balanced Rosenut real wood veneers, smart and well made.
Designed and hand-built in Great Britain.
Totally discrete input circuitry for high and low level inputs.
Separate volume controls for high and low-level adjustment
High quality gas-tight Neutrik Speakon input, panel-mounted twin photo inputs, LFE input
Simultaneous connection of high and low level sources
Variable Slam/Depth control (-9dB to +9dB) @ 80Hz
Attractive brushed alloy panel breaing a large blue front LED display with adjustable brightness
5-12V DC trigger input
Comes with Remote Control, High-Level Signal Cable, Spikes and user manual.
Frequency Roll-Off: 16Hz – 99Hz
Dimension: W345 x H520 x D370 mm
Weight: 30Kg.
Made in England.
Another REL with a natual 12 dB/octave final roll off.
+ Good shape of the frequency response for smaller rooms
+ Good extension
+ Extremely low group delay and fast decay rate
+ Extremely low crossover setting
A slice of pure, thoroughbred REL, albeit with some smarts
REL has enviable reputation for some of the most accurate, deepest and large sounding subbass systems around.
Storm 5, a medium-to-a-bit-bigger sized upright sub that stands above the carpet on rubber plinth feet (spikes supplied) with a characteristic
down-firing drive unit.
The grip and melodic ability belies the ‘mere’ 200W RMS power we are told is inside; the thing can growl like a very big carnivore indeed.
*Clean, Nice, 100% perfect working condition
*RM3950
*Welcome for audition
*Credit cards accepted.
*Contact OIO 267 397I
https://actsessory.com/pre-owned-used/
mav
Number of posts : 242
Registration date : 2010-09-21
Re: Rel Storm5 200-Watt MOSFET Subwoofer System, England
Post by mav on Sat Mar 04, 2017 4:45 pm
Cash / Credit card accepted
mav
Post by mav on Tue Mar 14, 2017 11:22 am
Welcome for audition...
mav
Post by mav on Thu Mar 23, 2017 1:41 pm
Location at Subang Jaya ss14
mav
Post by mav on Tue Apr 04, 2017 1:47 pm
item still available
mav
Post by mav on Thu Apr 13, 2017 12:20 pm
mav
Post by mav on Thu Apr 27, 2017 10:06 am
mav
