Harman Kardon HK-6800 High Current Stereo Integrated Amplifier with Phono MM and MC
Post by HiFiLab on Thu Apr 13, 2017 11:29 pm
Made In Japan
High Current Amplifier Capability
When it comes to amplifiers, most
manufacturers of stereo components
aim for impressive output figures
rather than outstanding design. The
Federal Trade Commission (FTC)
power test uses an 8-ohm resistor
across the amplifier's output leads.
But Harman Kardon recognizes that
an 8-ohm speaker can require up to
six times as much current as the
resistor. So, all Harman Kardon
receivers, integrated amplifiers, and
power amplifiers incorporate High
Instantaneous Current Capability to
properly drive any loudspeaker system
The result: The loudspeakers' drivers
are held more tightly in control, and
spontaneous dynamic demands are
satisfied-without clipping or
muddiness. Overall, Harman Kardon
amplifiers can deliver up to 10 times
more instantaneous current into low
impedance loads than do conventional
designs of the same power rating. It is
a triumph of craftsmanship over
specs-manship.
HK6800
High Voltage/High Current design.
All discrete components in signal
path.
Selectable power supply voltage to
optimize amplifier/speaker interface.
Electronic function switches on the
front panel control analog switches
at rear inputs for shortest and
cleanest signal path.
Interactive audio/video switching.
Main-direct switch.
Phase correct loudness.
Active/passive phono section.
MM/MC phono inputs.
2-way tape copy.
2 V CR/tape monitors (with video
switching).
Record out selector. 'Ibne defeat.
Subsonic filters.
Separate pre-amplifier out jacks.
Provisions for 2 pairs of speakers.
Heavy-gauge all-metal chassis.
Technical Specifications:
120 watts into 8 and 4 n FTC:"
High Current Capability : ± 90 amps.
Negative feedback: 12 dB.
Frequency response: 0.2 Hz-180 kHz.
Price : RM 1450
Contact Simon Ting : 012-3612507
Number of posts : 2238
BUMP
Post by HiFiLab on Sun May 07, 2017 8:04 am
Up
Post by HiFiLab on Tue Jun 20, 2017 8:51 am
up
