Technics SL-1100A w/ EPA-110 Tonearm + Technics EPC-270C MM Cartridge
Post by superfi on Sat Jun 03, 2017 4:45 pm
"The SL-1100 turntable provides that incomparable professional Technics quality in a reasonably priced package.
The heart of this outstanding direct drive turntable is its DC brushless motor which drives the platter directly to eliminate belts, pulleys and idlers.
This simple design means fewer moving parts to wear out and greater long term reliability.
The motor of the SL1100 is controlled electronically by a DC servo which provides highly accurate rotation completely unaffected by power line frequency and voltage variations.
And due to its high torque, speed remains the same even during changes of external drag.
This combination produces wow and flutter of just 0.03% WRMS and rumble of better than -70dB.
The SL-1100AC variant is identical but features an illuminated stroboscope."
Picture album here: http://imgur.com/a/D4yfL
Specifications
Type: direct drive player system
Platter: 350mm, 2kg, aluminium die-cast
Speeds: 33 and 45rpm
Motor: 20 poles (rotor), 15 poles (stator) ultra low speed DC motor
Speed change method: electronic
Variable speed control: 10% range
Wow and flutter: 0.03% WRMS
Rumble: -70dB
Tonearm: EPA-110 static balance type
Effective length: 235mm
Overhang: 14mm
Stylus pressure: 0 to 5g
Dimensions: 510 x 390 x 195mm
Weight: 13.0kg
Condition: 7.5/10, only cosmetically but otherwise in good working condition! Cue-level is a little rough, but is oiled and lowers the tonearm smoothly. Both 33/45rpm speeds are rock steady and can be adjusted manually via the speed adjusters.
Price: RM 2750 w/ Technics EPC-270C Cartridge, RM 2500 w/o cartridge.
Call Greg (011-39300083, 03-76104466) for more info, or come over for an audition at APS, Lot 223 2nd Floor Amcorp Mall!
superfi
Number of posts : 332
Registration date : 2012-05-24
