Harman Kardon PA2000 Power Amplifier
Post by gensiva1 on Fri Jul 07, 2017 10:30 am
Hi All,
Up for sale Harman Kardon PA2000 Power Amplifier
Condition: 8/10
Call or WhatsUp: Muhu on 010 563 7424
Price RM700.00 nego
Collection from Ipoh or Penang
Technical Specifications
Power Output
Normal Mode 4 x 45 watts @ 8 ohms, 20Hz – 20kHz, <0.07% THD, all channels driven
Bridged Mode 2 x 100 watts @ 8 ohms, 20Hz – 20kHz, <0.07% THD, all channels driven
High-Current Capability ±45 amps
Frequency Response <1Hz – 170kHz, –3dB at 1 watt
Signal-to-Noise Ratio 110dB at rated power 45 watts
THD/IMD Less than 0.07% at rated output
Power Bandwidth <1Hz – 100kHz
Input Impedance 47K ohms
Input Sensitivity 1 volt for rated output
Remote Trigger Voltage 3 – 30 volts AC/DC
Remote Trigger Impedance 20K ohms
Dimensions (H x W x D) 6-1/8" x 17-3/8" x 15-3/4"
155mm x 442mm x 400mm
Weight 25.3 lb/11.4kg
Power Requirements 120VAC, 50Hz/60Hz
260 watts, maximum
gensiva1
Number of posts : 18
Registration date : 2017-04-05
