FURUTECH Flux-50 NCF, High-End Performance, Top-Model, In-Line Power Filter from Japan
Post by meridian-506 on Thu Jul 13, 2017 1:01 am
For your consideration, an excellent condition, boxed, brand-new, top/current model FURUTECH Flux-50 NCF In-Line Power Filter, selling at RM3.5k.
This set is Brand-New, Boxed and has been run-in with a Cable Cooker.
This FURUTECH Flux-50 NCF In-Line Power Filter is Non-Current Limiting and is meant to be used between Your current Powercord and Equipment.
This Multi-Award Winner Flux-50 NCF is FURUTECH's Top End Performance In-Line Power Filter, featuring the Innovations Award Winning Top-Of-The-Line Silver-Plated Piezo Ceramic Rhodium-Plated α (Alpha) Nonmagnetic FI-50 NCF(R) Power Connector and the AC-1501R EMI-Filtering IEC Connector with Neo Damper Technology.
This FURUTECH Flux-50 NCF In-Line Power Filter is Made in Japan
Pictures Link :
Excellent detail can be found at the following Website / Reviews :
http://www.furutech.com/2013/02/02/1818/
http://www.6moons.com/audioreviews/furutech7/powerflux.html
http://www.dagogo.com/furutech-piezo-powerflux-power-cable-review
From FURUTECH's Facebook Page :
" The Flux-50 NCF is a sophisticated, luxuriously made and finished inline power filtering unit that eliminates many common problems caused by contaminated electrical power lines.
It protects against distortion caused by ground noise, voltage spikes and sags, high frequency power supply noise from other components in your own system, plus high frequency digital noise from processors and digital interconnects.
And while the Flux-50 NCF is a star performer at eliminating common AC problems, it does it all without restricting current draw in any way !
FURUTECH, known for its world-class Pure Transmission engineering, build and finish, have done the tests and the units does not interfere with current draw.
The AC-1501R EMI-filtering IEC input perfectly complements the remarkably effective Flux-50 NCF`s ability to eliminate distortion.
The Flux-50 NCF features the Innovations Award winning top-of-the-line silver-plated Piezo Ceramic rhodium-plated α (Alpha) nonmagnetic FI-50 NCF(R) power connector.
They combine Three "Active" Materials: Nano-Sized Crystalline, Ceramic Particles and Powdered Carbon.
Nylon and fiberglass are incorporated as well forming an extremely effective, mechanically and electrically non-resonant connector body that may just be the most sophisticated in the world.
And it incorporates the AC-1501R EMI-filtering IEC connector with Neo Damper Technology.
The Flux-50 NCF Inline AC Filter Lowers Noise On Every Component On Which It Is Used, Resulting In Very Natural and Extremely Fine Resolution Down and Through The Utterly Silent Noise Floor.
It Improves Soundstaging and Image Palpability and Creates Musical Highs, An Attractive, Engaging Midrange, Tight and Controlled Bass, Plus You'll Notice Power and Dynamics To Spare."
Incorporated into select FURUTECH products, Nano Crystal2 Formula --- NCF is comprised of a special crystalline material that has two "active" properties.
First, it generates negative ions that eliminate static and secondly, it converts thermal energy into far-infrared.
FURUTECH then combines this remarkable crystalline material with nano-sized ceramic particles and carbon powder for their additional "Piezo Effect" damping properties.
The resulting Nano Crystal2 Formula is the ultimate electrical and mechanical damping material - only found in FURUTECH products! Nano Crystal2 Formula eliminates static, "interconverts" thermal, mechanical and electrical energy and damps vibrations - all for the finest FURUTECH Pure Transmission signal imaginable.
Originally purchased from the Local Agents in Singapore, this FURUTECH Flux-50 NCF In-Line Power Filter is safe for local usage.
Actual set as pictured above, this FURUTECH Flux-50 NCF In-Line Power Filter is in excellent condition & comes with the original Box.
Payment mode will be on a C.O.D. basis.
Collection can be done in JB, KL, Ipoh, Penang or Butterworth at no extra charge - for other collection locations, kindly contact me.
Shipping via PosLaju is also available.
If you are interested, please respond via a PM or send an e-mail with your contact number to :
meridian-506@hotmail.com
Thank You for viewing my ad. Smile
meridian-506
Number of posts : 948
Registration date : 2010-11-25
Re: FURUTECH Flux-50 NCF, High-End Performance, Top-Model, In-Line Power Filter from Japan
Post by meridian-506 on Wed Jul 19, 2017 12:49 am
B.U.M.P. Very Happy
meridian-506
