Proficient Audio W690 6.5" In-Wall or Ceiling Mount 150W Speaker White
Post by HiFiLab on Mon Oct 23, 2017 9:25 pm
PROFICIENT W690 6.5" KEVLAR IN-WALL SPEAKERS, 1" PIVOTING TWEETERS, 150W
Proficient Audio W690 6.5 In-Wall Speaker – Pair (White) is best for you
When it’s power and glory you want the W690 really comes through. A 6.5′ woofer with cast magnesium basket a 1′ aluminum-dome pivoting tweeter bass/treble contour switches and 150 watts of power handling make for an incredible sound experience.
Put on your favorite music or movie then get ready. Here’s the best 6-1/2-inch single-woofer in-wall  Proficient has ever offered. The W690 has a woofer for ultra-deep bass power and low distortion and a pivoting aluminum-dome tweeter for clear extended treble. High sensitivity means that even a low-powered amplifier can get the W690 really cranking! Fiber can’t stretch which is why it reduces distortion in a speaker and why we chose it for the W690’s woofer cone. The W690’s 6-1/2-inch woofer puts out incredible bass down to 32 Hz which is lower even than some subwoofers can play! A cast magnesium basket provides a super-stiff frame for the powerful woofer.
The W690’s 1-inch aluminum-dome reproduces high frequencies with clarity and power and it also pivots so you can direct the sound where you need it. Boost switches for bass and treble provide an extra +3 dB kick when it’s needed. With 92 dB sensitivity and 150-watt power handling the W690 works great with amplifiers of any power rating. Specifications: 6-1/2′ Woofers Cast Magnesium Woofer Baskets 1′ Pivoting Aluminum Dome Tweeters +3db Bass & Treble Contour Switches Power Handling: 150 Watts Frequency Response: 32Hz – 22kHz Impedance: 8ohms Sensitivity: 92dB 1W/1m Dimensions (H x W x D): 12-1/4′ x 8-3/16′ x 3-3/16′ Wall Cut Out (H x W): 10-7/8′ x 6-3/4′
General/
Type                           Speaker
Speaker System Type   speaker
Additional Features       rotatable tweeter
Manufacturer               Proficient Audio Systems
Speaker System/
Amplification Type           passive
Crossover Channel Qty     2-way
Nominal Output Power      150 Watt
Frequency Response        32 - 22000 Hz
Nominal Impedance         8 Ohm
Sensitivity                       92 dB
Connectivity Technology   wired
Recommended Placing      in-wall Or Ceiling mounted
Controls                          bass, treble
Driver Diameter               1" m ( Aluminium Tweeter ), 6.5" m ( Kevlar Woofer )
Dimensions & Weight/
Width                     8.2 in
Depth                     3.2 in
Height                    12.2 in
Cutout & Mounting Dimensions/
Width                     6.7 in
Height                    10.9 in
Very Good sound quality. I have the proficient c850 as center channel and the c660 for the surround with a Onkyo 606 reciever pushing them all. These speakers are some of the best I've heard. I recommend these to anyone looking for clean sound and clarity.
Price : RM 950  Pairs
Contact Simon ting 012-3612507
Number of posts : 2240
BUMP
Post by HiFiLab on Sat Apr 07, 2018 9:27 pm
Up
