MARANTZ SR7001 THX select 2 surround sound HDMI A/V RECEIVER
Post by jbashok on Sun Dec 17, 2017 10:37 pm
MARANTZ SR7001 THX SELECT2 SURROUND SOUND A/V RECEIVER
Ipoh, Perak
RM1,480
The SR7001 features THX Select2 certification and 110 watts of continuous power per channel (yes, 110 watts from each of its seven
current-feedback amplifiers!). You can connect up to four HDMI equipped sources to the SR7001. The SR7001 comes complete with format
conversion which lets you watch older videos through the super-convenient HDMI format, and there’s also a Second Zone audio/video
output. You’ll also find Dolby Virtual Speaker so you can enjoy an immersive surround experience with the dialog clarity inherent in a
discrete center channel configuration with just two speakers. The SR7001 features Audyssey’s remarkable Auto Calibration that examines
your entire room to corrects for the acoustical problems that sometimes make those other seats (and you know which ones we mean, don’t
you?) just as rewarding as the ones directly in front of your display device’s screen. The SR7001 has an infrared input and two DC trigger
outputs so you can coordinate your entire system for convenient remote operation. We’ve housed the SR7001 in a new, compact chassis,
( less than 16”) that will fit more easily into even the tightest spaces. The SR7001 also comes with our industry leading three year warranty.
• 110 watts (into 8 ohms) x 7 ch Amps
• THX Select2 certification
• All discrete “Current Feedback” amplifier stages
• HDMI (V1.2) Repeating: 4-In / 1-Out
• 32bit DSP
• XM Ready with discrete IR commands
• Dolby Digital EX, Pro Logic IIx (Movie/Music/Game),
• DTS 96/24, ES (Discrete 6.1/Matrix6.1), Neo:6 (Cinema/Music)
• SRS Circle surround II
• Audyssey Auto Calibration
• Up-Conversion (w/TBC) to HDMI with 480I/480P converter
• Dual Component Video outputs
• 192 kHz/24-bit D/A converters for all channels
• HDCD®️ Decoder
• Dielectric Protected Binding Posts
• Speaker A/B switching
• 2nd Zone A/V output (Individual source) w/discrete commands
• Dolby Headphone
• Lip sync. control
• Assignable HD compatible component video
switching (4 in / 2 out)
• RS-232C terminal for system control
• Direct IR Flasher Input
• x2 DC Trigger outputs
• D-BUS (RC-5 In/Out) remote connection
• Front panel A/V/Optical inputs
• Learning/pre-programmed backlit remote with LCD
• 1 switched and 1 un-switched
Mint condition seldom used very well performance powered by marantz .
[Sony 3D blu ray player with LAN support sell separate RM 200]
personal delivery to KL considered
Whatsapp 0143413655
Last edited by jbashok on Fri Feb 23, 2018 1:16 pm; edited 1 time in total (Reason for editing : update details)
jbashok
Number of posts : 463
Registration date : 2017-01-03
Re: MARANTZ SR7001 THX select 2 surround sound HDMI A/V RECEIVER
Post by jbashok on Mon Dec 25, 2017 5:24 pm
UP
jbashok
Post by jbashok on Tue Jan 02, 2018 2:03 pm
up
jbashok
Post by jbashok on Sat Jan 13, 2018 12:10 am
up
jbashok
Post by jbashok on Mon Jan 22, 2018 12:19 pm
up
jbashok
Post by jbashok on Wed Jan 31, 2018 12:09 am
up for a good stuff
jbashok
Post by jbashok on Wed Feb 07, 2018 12:57 pm
up
jbashok
Post by jbashok on Thu Feb 15, 2018 3:04 pm
up
jbashok
Post by jbashok on Fri Feb 23, 2018 1:18 pm
up
jbashok
Post by jbashok on Sat Mar 03, 2018 6:38 pm
UP
jbashok
Post by jbashok on Sun Mar 11, 2018 10:07 am
PRICE  NEGO
jbashok
Post by jbashok on Sun Mar 18, 2018 2:38 pm
UP
jbashok
Post by jbashok on Sun Mar 25, 2018 9:36 am
UP
jbashok
Post by jbashok on Tue Apr 03, 2018 9:52 am
up
jbashok
Post by jbashok on Wed Apr 18, 2018 9:18 pm
up
jbashok
