Pioneer SBX-101 Bluetooth Soundbar + Wireless Sub
Post by on Mon Mar 05, 2018 4:44 pm
Pioneer SBX-101 Bluetooth Soundbar + Wireless Sub Brand New, Now Selling At RM799. Free Shipping Within West Malaysia.
Please visit [You must be registered and logged in to see this link.] to find out more products for sale at very special price...
Interested please feel free to contact:
Peter  012-2536225
Fong   016-3098668
Business hour:
Style Online Store 24Hous
No.148, Jalan Cerdas, Taman
Connaught, Cheras 56000 Kuala Lumpur
We buy in your old items in CASH!!
Got something keep at home but seldom use or planning to upgrade?
Items that we buy:
BRANDED led tv
cd player
Please Whatsapp the item photo to me and get the price immediately, once confirmed the deal, we will pick up your item from you and pay you in cash.
Not feeling a complete movie experience? Popular Music Video sounds dull and soft? It’s time to upgrade the sound system for your TV! With the latest Pioneer Speaker Bar System SBX-101, it delivers big,immersive sound in a relatively affordable package, making it worthy of your living room, no matter what your needs are. Whether you're watching an explosive action movie or just kicking back with some music,the SBX-101 has enough deep bass and crisp highs to make all of your media shine. Although the SBX-101 has a slim and lightweight design, it provides stunning sound,and a wide range of connectivity for most TV and AV products in the market to maximize compatibility. With a wireless connected subwoofer, the position of the speaker can be more flexible. You can easily play music files via the USB interface. In addition, with the built-in Bluetooth®️ function, you can also stream music from your smart phone with ease.
High-power output brings you the best sound quality and stunning surround sound experience
SBX-101 features a separate speaker bar and subwoofer: the speaker bar is designed to produce high and mid frequencies, generally vocals,instrumental music and environmental sound, whereas subwoofer adds a very specific and valuable quality to your home theater sound experience - you can feel the sound. The low frequencies produced by a subwoofer are typically made by musical instruments like bass drums,pipe organs, string bass and bass guitar, and movie sound effects like the rumble of a rocket launch. Compared to the flat and muffled sound from the average TV, SBX-101 brings a tremendous upgrade to the sound quality. With the 108 W maximum power, the output of SBX-101 is more than enough for most small houses.
Speaker bar won’t block your TV screen
While new flat-panel TVs are designed with a thinner bezel, there is less space for the built-in speakers. Given the less amount of space underneath the TV, positioning the speaker bar can be more difficult.The height of the SBX-101 is only 60 mm and it can be placed in front of most TVs without blocking the screen or even the subtitles. Nor will its smaller footprint affect the overall appearance of the TV either.
Wireless woofer makes connection and installation much easier
To provide deeper bass, the SBX-101 features a separate speaker bar and wireless subwoofer but the installation and setup are quite easy.After plugging in the AC cables,press the pairing button on the subwoofer to establish a wireless connection between the two units, and then the subwoofer will connect automatically the next time when speaker bar gets powered on. The SBX-101 provides AUX-IN, 3.5 mm Line-in and Optical inputs. Users can select an appropriate interface for their TV connection, and then the entire installation process is complete.
Dolby Audio™️ technology makes the sound more immersive
Dolby Audio™️ technology from Dolby Laboratories is designed to restore digital movie audio at home to the audio quality close to that of commercial cinemas. This allows users to stay at home while at the same time enjoying the harmonious and powerful sounds of movies and TV shows where both the audio and visual elements can be more fully experienced. Dolby Audio™️ technology also allows 5.1-channel surround sound to be immediately remixed and converted to sound output suitable for a speaker bar configuration.
Hidden LED indicators show all the status
Under the SBX-101 speaker grille, there is a set of hidden LED indicators, by which users can easily understand the current operating status of the speaker bar and see clearly if the operation commands are received. Users will no longer need to point the remote control at the speaker bar aimlessly without getting any visual feedback.
Speaker Bar: W42 x H47 x D157 mm / Full-range Cone
Wireless Subwoofer: W133 x H133 x D76 mm/5-1/4”Cone Woofer x1
Type: Class D
Channels: 2.1
Max. Power Output: Total 108 W (Speaker Bar + Wireless Subwoofer)
THD 30 %, 6 ohms
-Speaker Bar: 30 W x 2
-Wireless Subwoofer: 48 W
Dolby Audio™️
Bluetooth®️ Wireless Technology PLAYABLE FORMATS
Audio: MP3 (.mp3), WMA (.wma), AAC (.m4a), WAV (.wav),FLAC (.flac), Monkey's Audio (.ape)
USB in x 1
Line in x 1
Optical in x 1
AUX in x 1
Power Requirements: AC 100~240 V,50/60 Hz
Power Consumption/Standby: ≤ 0.5 W
Power Consumption During Standby:≤ 1.8 W (Network Standby Mode)
Dimensions (W x H x D)
-Speaker Bar: 880 x 55 x 80 mm
-Wireless Subwoofer: 200 x 292 x 230 mm
-Speaker Bar: 1.59 kg
-Wireless Subwoofer: 3.0 kg
Thanks for viewing.
Number of posts : 107
Registration date : 2018-01-20
