Marantz PM-6100SA Japan Made Stereo Intergrated Amplifier with Remote
Post by HiFiLab on Wed Mar 21, 2018 6:23 pm
Made In Japan
Description :
Aimed at the next generation of audiophiles, the Marantz PM6100SA integrated amplifier inherits the design concept and the advanced circuitry technology of the PM14SA and the PM-17SA. The preamplifier part adopts high current feedback drive capacity through low-noise/high slew rate, and secures the dynamic range. The power amplifier adopts current feedback, and high speed is attained.
Specifications :
Output Power..............................70W + 70W at 4 ohms, 20Hz to 20kHz, both channels driven
                    ..................................60W + 60W (6 ohms)
                    ..................................50W + 50W (8 ohms)
Total Harmonic Distortion..................0.01% at 8 ohms load intensity
                                     ..................20Hz to 20kHz, both channels driven
Cross Modulation Distortion..............0.01%
Output Bandwidth............................10Hz to 50kHz at 8 ohms load intensity, 0.04%
Frequency Response........................5Hz to 60kHz, +0/-1 dB (CD, source direct)
Dumping Factor...............................100 at 8 ohms load intensity or more at 20Hz to 20kHz
Input Sensitivity/Impedance...............Phono MM: 2.3mV / 47k ohms
                                         ...............High Level: 200mV / 15k ohms
Maximum allowable Phono Input.......MM : 130mV at 1kHz
RIAA Deviation.................................+/- 0.2dB at 20Hz to 20kHz
Signal-to-Noise Ratio........................Phono MM: 85dB (IHF A-weighted, input short circuit)
                             ........................High Level: 110dB
Loudness........................................100Hz : 8dB
             ........................................10kHz : 3dB
Tone Control....................................Bass : +/- 8dB (100Hz)
                  ....................................Treble : +/- 8dB (10kHz)
Supply Voltage................................110/220V AC, 50/60 Hz
Power Consumption.........................155W
Dimension(w x d x h)........................44 x 35 x 12.5 cm
Weight    ............................................7kg
Come with original Remote Control
Can use as Pre-Amplifier
Price : RM 950
Number of posts : 2240
BUMP
Post by HiFiLab on Sun Apr 15, 2018 10:32 pm
Up
