NUPRIME DSD -portable DAC with head-amp built-in.
Post by jbashok on Sat Mar 31, 2018 3:16 pm
RM490
Ipoh, Perak
NuPrime uDSD -portable DAC. Decodes 24-bit PCM384 & native DSD256 files.
The NuPrime uDSD, a significantly audiophile grade advanced hi-resolution USB-powered portable DAC with head-amp built-in.
Features direct DAC out (analog out) and Coaxial S/PDIF, for a broad variety of systems.
It connects your personal computer's audio to your home stereo, desktop sound system and headphones.
The powerful headphone amplifier circuit, built on a sophisticated balanced design, provides the uDSD with the ability to drive almost any of today's headphones -- a feature that can also be used to drive active speakers.
Decodes the latest high-resolution music formats, ranging from 44.1kHz to 384kHz (PCM) as well as native DSD decoding from DSD 64 up to DSD 256.
With its native DSD-format decoding capability, uDSD is ideal for upgrading existing high-end non-DSD DACs.
A palm-sized rock solid aluminum enclosure provides durability and elegant style.
Features:
- 24-bit/384kHz and native DSD 256 support
- Discrete USB audio receiver and D/A converter, with coaxial S/PDIF (24bit/192kHz) output
- Coaxial output can also stream DoP (DSD64) for long distance transmission of DSD from computer
- Asynchronous transfer mode for doubled jitter-reduction at data input and over-sampling filter stages
- High-performance headphone amplifier (balanced design)
- High voltage 2V analog output (fixed volume direct DAC output)
- Coaxial S/PDIF output
- High-quality analog volume control
- Diminutive sizeĀ
- USB powered, no external power supply required
- Works with Windows 7/8 and Mac OS.
Specifications:
Input: USB 1.1, 2.0, compatible.
Output:
- Analog Stereo RCA Out
- Digital Coaxial Out.
- Headphone Amplifier Out (3.5 mm-jack socket)
- USB sampling rates: 44.1,48,88.2,96,176.4,192,352.8,384KHz and DSD 2.8,5.6,11.2MHz.
- Bit resolution: 16-24-bits.
- Output: Analog RCA 2V rms (DAC out).
- Headphone output: max 140mW x 2 @ 32 ohm.
- Dynamic range: 98dB.
- S/N ratio: 112 dB.
- THD+N < 0.01%.
- Power: USB-Bus powered, 150mA/5V.
WHATSAPP----- 0143413655.
jbashok
Number of posts : 574
Registration date : 2017-01-03
Re: NUPRIME DSD -portable DAC with head-amp built-in.
Post by jbashok on Sun Apr 08, 2018 1:04 pm
up
jbashok
Post by jbashok on Thu May 03, 2018 8:20 pm
up
jbashok
Post by jbashok on Fri May 18, 2018 1:24 pm
up
jbashok
