Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93
Post by actsessory on Thu Jun 07, 2018 2:55 pm
  • Non-Destructive-Modification of Linear Power Supply UPGRADE!
  • Specially developed for Oppo BDP-103D / 103 / 93
  • Custom made fully isolated toroidal transformer
  • Imported HiFi grade components
  • Meticulous craftmanship
  • Precision engineering
  • A comprehensive upgrade kit
  • OPT: Digital SILVER Version available!!
Fully isolated, HiFi-grade, ultra low noise non-destructive-modification linear power supply, specially developed for OPPO BDP-103D / 103 / 93
Zero-Zone is committed to developing a dedicated HiFi grade linear power supply upgrade.
Based on the serious HiFi grade components for audiophile as well as videophile performance.
Oppo, and most dvd/bluray players stock power board is of SMPS (switch-mode power supply), due to their efficiency, low cost and ease of manufacturing.
SMPS provides high current, low and multiple voltages easily and cheaply.
They generate a lot RFI (radio frequency interference) at the switching frequency of the supply.
Linear Power Supply provides clean constant voltage and stable current at the output stage.
It provides isolation between the output and input because of the toroidal transformer.
An instant performance upgrade solution.
A 50VA pure copper toroidal transformer tailored specifically for 103D / 103 /93, optimized for low frequency density, strength and depth.
Build of ELNA, Nichicon, Philips etc capacitors structure array involved in the performance tuning.
4mm thickness aluminum full spec base, high strength, guaranteed heat dissipation, relatively to the bearing of just PCB board.
Schuter fuse folder for fuse changing to personal preferences.
Contributes outstanding processing power, constant voltage, stable current to your player.
Full HiFi audiophile grade components supplying juices to the analog decoding board, no longer sounding "tasteless"...
AV-phile grade components with meticulous craftmanship.
Price:  RM580
*  1 Year Local Warranty
*  Installation is provided upon request
************************THIS IS NOT THE END YET....****************************
The Digital SILVER Version non-destructive-mod of Linear Power Supply
Specially developed for Oppo BDP-103D / 103 / 93,  non-destructive modification of Linear Power Supply upgrade.
This digital silver version is more inclined to digital circuit optimization.
Specifically tailored Silver-plated pure copper transformer
Secondary direct leads output to the power board.
High precision, ultra low ripple wave resistance, high speed stablized power supply module - specially tailored for digital circuit.
Imported HiFi grade components.
Provides outstanding processing power, constant voltage, stable current for 203's digital part (motherboard)
*The Digital SILVER Ver upgrade is fully optimized for digital power output, to the motherboard for digital input/outputs (HDMI, Coaxial, Optical, USB, Optical Drive)
**Thus the analog audio board (7.1 channel analog output) will be disabled, this will suit the users to have the best performance from the digital in/out while not using the analog outputs.
Price:  RM750
~~~OPTIONAL UPGRADE KITS:
i) Oppo dedicated IEC power upgrade kit. It's Pure Silver cable,  not silver-plated copper.
Made from Gold-plated power inlet IEC, pure silver cables.
ii) Oppo dedicated analog power upgrade kit
Made of silver-plated pure copper OCC cables, lead-free soldering.
iii) Oppo dedicated digitalg power upgrade kit (coming soon...)
actsessory
Number of posts : 1026
Registration date : 2013-10-25
http://www.actsessory.com
Re: Linear Power Supply module upgrade for OPPO BDP-103D / 103 / BDP-93
Post by actsessory on Thu Jul 05, 2018 8:09 am
All these are from same owner..!
With his BDP-93 upgraded with NuForce Extreme Edition sound board.
actsessory
