Rotel RB-980BX 120 Watts Stereo Power Amplifier
Post by HiFiLab on Fri Jul 13, 2018 10:01 pm
Made In Japan
Product Information
Enhance the sound quality of your music system with the Rotel RB-980BX bridged amplifier. With a nominal output of 120 watts per channel at 8 ohms, this Rotel amplifier gives a more defined sound at room-filling volume levels. The 120 dB signal-to-noise ratio of this bridged amplifier effectively reduces the background noise. The frequency response range of this Rotel amplifier is 4-1,00,000 Hz, enabling you to listen to a range of sounds. The 0.03 percent THD of the Rotel RB-980BX reproduces sound accurately by reducing the harmonics.
User Review :
The amp was solid and very quiet. Great bass response, imaging and sound stage. It was also well made and robust in construction.
delicate, more controlled sound in all the frequency range, Bass still powerfull, but musical, fast and precise, sweet mids and non agressive relaxed, smooth highs. Soundstage opened noticeably. I enjoy 'em for hours without fatigue
Power output: 120 watts per channel into 8Ω (stereo),
360W into 8Ω (mono) Bridge Mode
Frequency response: 4Hz to 100kHz
Total harmonic distortion: 0.03%
Damping factor: 1000
Input sensitivity: 1V
Signal to noise ratio: 120dB
Speaker load impedance: 4Ω (minimum)
Dimensions: 440 x 120 x 323mm
Weight: 10.2kg
Price : RM 1680
Number of posts : 2321
